Roam has open api, can you do a roam integration?
Do you have a pointer for information on such a public API? Last time I looked Roam did not support integration and had only a private API that was focused around customization of their app, not integration with outside apps.
@agiletortoise You can see this link below for details: https://twitter.com/RoamResearch/status/1674836371880411146?s=20
I’ll keep an eye out if they release something final, but this links to an incomplete beta API, that hasn’t had any updates on status since last November. That’s not appropriate for use for any direct integrations.
That said, there should be no reason one could not build actions using existing HTTP scripting in Drafts if you want to play around with those options.
