hi, guys. how do I make a script that defines a specific text for a draft, such as a template?
Here’s an example in the action directory which does exactly that…along with assigning tags:
One option would be to use the Insert Text step in an action. This inserts the text in the action at the cursor. You could always create an additional step to create a new draft if required.
If you are a TextExpander user, you could also define it as a snippet; Drafts being a ‘TextExpander enhanced’ application.
Very Tks!!!
Done!!!
