podiboq
September 23, 2022, 7:27am
1
Hi there,
I’ve uploaded a syntax to the directory, but forgot to rename it. So I’ve created another one and re-uploaded it.
The problem is that I removed the first one from Drafts, and now I have no idea how can I remove it from the directory…
Here’s the link : Markdown | Drafts Directory
Anyone has an idea?
Thanks
sylumer
September 23, 2022, 9:26am
2
I think Greg would have to “admin” that one unless you could restore it locally from a backup.
I took care of it.
Do you remember getting warned when you went to remove the syntax about the linked Directory post? I think it should have warned you that you would be orphaning that listing.
podiboq
September 23, 2022, 12:21pm
4
Thank you.
Nope, I don’t remember seeing a message or something…
