gerry
July 15, 2022, 3:33am
#1
Often, but not always, the Quit menu (macOS) is inactive and I can’t quit the app without force quitting it via the Activity Monitor app.
I’m running the latest version on macOS Monterey 12.5 beta (but it was happening with the 12.4 release version too).
Hmm, that’s not one I have ever seen or heard of…not sure what to suggest. I’m not aware of anything the app ever does to intentionally disable Quit
No clue as to what precedes the app getting in this state? Related to any particular activity in the app, or certain window being open, etc.?
Could here be a modal dialog up that somehow is obscured?
gerry
July 17, 2022, 11:41am
#4
I checked for that. Not modals, anywhere…
JJed
August 3, 2022, 12:59pm
#5
I have been experiencing this issue also - first noticed it about a week ago but it is happening consistently.
I can force quit, but the menu bar option is greyed out.
The thread linked above offer the solution to this problem, including ready to install example MultiMarkdown syntax that favors accuracy over performance. See:
There is an example syntax in the directory that uses full text evaluation. If this is important to you, you can install and use it instead of the default MultiMarkdown syntax:
