I discovered QuickSearch! I have been using the normal search and then have to filter manually by tagged or untagged, not knowing that QuickSearch exist.
I edited the Alfred workflow to use QuickSearch drafts://x-callback-url/quickSearch?query={query} and found that while the result showed the correct list, the search term is not shown in the text field.
“hello” should be shown in the red box, instead of blank.
The same workflow, when using the usual search drafts://x-callback-url/search?query={query}, will show the search term
