Hey folks, long time listener, first time caller.
I’m coming back to Drafts after some time away as I overhaul my workflows, using it to send to both Devonthink and Things.
Is there a way to have an action immediately executed after using the quick entry window? I’ve hunted around and can’t find a clear answer there.
Any pointer in the appropriate direction are appreciated. Thanks in advance!
There is no “automatic” triggering of actions available. If you want to process a capture immediately, you can use the “Open” option to jump to the created draft from capture, and trigger an action on it.
If you’re a Raycast user then you could do that using my raycast extension for Drafts:
Yeah, that’s what I’m talking about, right there. Thank you.
Raycast was not on my radar, I’ll be exploring this more deeply.
I’m also using a couple of your Draft actions, @FlohGro , thank you!
That’s great to hear @jmstovall1 - let me know if you get this working for you and if you miss anything
