When using the Quick Capture window on Mac, if I try to drag the window to a new position on the screen I seem to always click into the ‘Add tag’ textbox in the window’s title bar instead, which means you can’t drag it. Anyone else? Is there any way to make the text box narrower to stop this happening, or do I just need to be more careful where I click?
The weird thing is that I don’t remember this being a problem a month ago, so I don’t know if something’s changed?
Thanks
