Hi all, I no longer can use the Post to Medium action. I get this error message: “Unable to fetch user ID. The operation couldn’t be completed. (OAuthSwiftError error -11.)”
I have deleted and reinstalled the action, deleted and recreated the Medium integration token, tried putting the token in various fields in the action. No luck.
My best guess is that your credentials were expired for some reason. Go to Drafts Settings > Credentials and “Forget” your Medium credentials (related docs). Then try the action again, and you will be prompted to re-authenticate.
