I can no longer add drafts using the FlickType keyboard which I was using every day and it was the main reason for becoming a Drafts subscriber.
Specifically, when I try to add a new draft using the Flicktype keyboard I get a choice dialog:
Download “FlickType Keyboard” from the App Store?
Download now
I already have it
If I choose “Download”, it opens the App Store on the Flicktype page where I can only select the Open button which opens the Messenger app and I can create a new message using the FlickType keyboard without any problem.
If I choose “I have it already”, it goes straight to the Flicktype Keyboard where I can enter a string, hit DONE, and get an alert “URL Failed to Load - this URL can be viewed on your iPhone". The only option is to Dismiss this dialog and it goes back to the keyboard.
I have tried to delete both Drafts and FlickType and reinstall them without any results.
I use the 8.7 version of WatchOS (Apple Watch 4) because I have an iPhone SE, which is stuck on the 15.7 iOS. I use the 34.2 Drafts version (182) and the 2021.12 version of FlickType.
Any help is appreciated!
