This action has turned out to be really helpful to me. I originally had some CSS files in Dropbox, but I couldn’t pull the file names into Drafts without adding them to the script manually (as of now). So I thought, why not just maintain the CSS files in Drafts? If you have a few different CSS files you like to use, or if you like to be able to edit the CSS and see the results quickly, this is a whole lot faster than going into the action editor every time.
http://actions.getdrafts.com/a/1JN
//Process MD with CSS from Drafts "css" tag:
const tag = 'css';
const draftsFound = Draft.query("", "all", ["css"]);
const draftAry = [];
//Sort drafts by modified date
draftsFound.sort((a, b) => {
return a.modifiedAt < b.modifiedAt;
//Create array with draft names and UUID
for (let d of draftsFound) {
draftAry.push([d.title.replace(/[*\/]/g, '').trim(), d.uuid]);
//Load array in to a Map
const draftMap = new Map(draftAry);
const p = Prompt.create();
p.title = "Choose CSS";
p.message = "Pick CSS file to render document"
draftMap.forEach((v, k) => {
p.addButton(k);
const response = p.show();
if (response) {
console.log("CSS Draft Title: " + p.buttonPressed);
const pickedDraft = draftMap.get(p.buttonPressed);
//Get draft CSS contents and load into template
if (pickedDraft == draft.uuid) {
context.fail("Cannot apply CSS file to itself!");
} else {
const css = Draft.find(pickedDraft).content;
draft.setTemplateTag("css", css);
} else {
context.cancel();
Inject the CSS into the HTML preview:
//Simple HTML template
<!DOCTYPE html>
<html dir="auto">
<head>
<title>[[title]]</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
<style>
[[css]]
</style>
</head>
<body>
%%[[draft]]%%
</body>
</html>
It’s been great so far. I’m absolutely loving drafts!
Nick
