Hey all! First time Drafts user and first post. I was sold on Drafts for the ability to post to my self-hosted websites using Wordpress.org NOT the hosted Wordpress.com site. I enter my credentials including the website User and Password. Posting to Wordpress fails every time. I check the Action Log as suggested in the forums and received the error: “HTTP Error: 404, not found WordPress posting failed”. I’ve updated the password and verified credentials are correct but no change. Using Drafts version 32.0 (57) on MacBook. Any advice for a newbie before I delete Drafts in favor of another solution? Thank you!
A 404, and as per the description,means it can’t find the URL entered for your site in the credentials. Try removing and re-adding the credential in case you had a typo.
Can you get to https://my-wordpress-site.com/xmlrpc.php (replacing the base URL of your site + xmlrpc.php)?
You should get a page that just says only POST requests are accepted.
If you cannot, it might mean either remote posting is disabled in your Wordpress config, or your hosting provider blocks XML-RPC by default, which many do and you have to request them enabled it for your site.
Thank you for the prompt reply. I will work with my host and have it resolved.
