I’ve been trying to find the option to pin the side drawer in my iPad Pro and iPhone 7 Plus but can find it. How do I pin the side drawer?
Hold on the “drag handle” that appears when the drawer slides out. After a long press you’ll see the editor resize and it’s pinned. To unpin, long press again.
Problem solved, thank you!
One thing to note for Plus users: if you have the display zoom setting turned on, you won’t have that option. Something to keep in mind!
Thanks. It’s so secretive!
Thank you I have been looking for this too.
