I created Paragraph Mode as a prototype.
I think Arrange Mode should allow actions to be run against selected paragraphs or lines. As that isn’t the case I wrote this piece of javascript that:
- Pops up all the paragraphs (2 x
\n\nas the delimiter) in a dialog with a paragraph number and a check box against each. - Allows you to pick an action from a small range and hit the “Apply” button to apply it to selected paragraphs.
- Allows you to use the “Save” button to save back all the paragraphs.
You can easily modify the javascript to add actions. The ones I started with are simple and aren’t intended to be that useful.
As I say, this more shows the idea of applying actions to selected paragraphs than anything.
Feel free to take this and enhance it.
(There are a few issues with the layout on both Mac and iOS with the Prompt class.)
