Open drafts goes to archive view
I needed to restore my drafts. Long story. All good, but now when I open drafts, the screen opens to the archive view, not the inbox.
I would like it to open to the inbox.
What do I need to do?
Many thanks.
Possible there was some corruption of your default workspace in the resync.
What happens if you tap the (x) to clear filters above the drafts list? Does it move to the archive tab, even if you had the inbox selected?
Thanks for your help. When I tap the (x), the view moves to archive, even if it was showing the inbox. Also, I quit and reopened Drafts and had the same result when default view is archive view not inbox.
Install and run this action. It will reset your default workspace options, and should resolve this problem. You can delete the action after it has been run.
Thank you. I ran the action you created. After I tapped the (x) after quitting and reopening, the filters cleared and Drafts now opens to Inbox as before.Many thanks for the great app and your support of users. Much appreciated.
GM
