Onedrive monthly
is it possible to create and update a onedrive monthly journal?
The default “Basic” action group has an “Append to OneDrive Journal” example that does that. If you do not have it in your installation, you can get it from the directory:
I looked for Monthly Journal…
Create an action that appends to a file named Journal-[[%Y-%m]].txt and it will start a new journal each month.
