Using the obsidian (file) action and while the markdown file shows up in the files app, it does not show up in obsidian. I am using iCloud for storage and obsidian sync. Any suggestions?
- Is the resulting file a
.mdfile? - Is the file location a definite match for the vault?
- Do other Markdown files in the same location show in Obsidian?
- Is the file name recognised as a valid filename for an Obsidian Markdown file? E.g., it does not start with a period.
- Can you open the file in a text editor app to ensure it is downloaded to your device?
- What platforms (operating systems/devices) are you using and is the issue persistent across them?
- Can you provide a link to the action you are using?
for some reason it. has started working. happy days
