I’m wondering if its possible to integrate drafts with notion on two accounts. I have a personal and a work notion account and I’d like to create actions for both of these accounts. Is there a way to work through this?
Notion integration uses the same Credentials system that all most of the built-in integrations use. You need to have separate actions, and specify credential identifiers on the actions to indicate which account they target. More details in the User Guide.
This is helpful. Resolved my issue. Thank you.
