Long time drafts user. I’ve just upgraded to Drafts pro and embraced workspaces. I found them a little bit unintuitive to setup and get my drafts in the right spaces, and the pro page wasn’t very helpful, but I worked it out.
Now I have 4 workspaces, one is for templates which I want to open in Omnifocus, so I don’t want that workspace to count towards the notification badge on the drafts app on IOS, but I do want the other three to. The templates aren’t waiting on my to do anything, but the other three workspaces are unfinished pieces of work.
I can’t see a Way to do this, if I’m understanding correctly, you can only pick one Workspace to count towards the number on the notification badge. Is this true?
As mentioned. You could make another workspace to control the badge. Many make one that only shows “untagged” drafts.
You could also keep your template drafts in the archive instead of the inbox. You can even setup your template workspace to auto-select the archive tab when applied.
