Apologies as javascript is not my language of choice - my searches yielded nothing that helped.
I have some metadata in a configuration draft. I have an action that reads that in and uses it to build a new draft. It all works quite well except…
For some of the metadata it would be nice if it could be used to insert newline characters into the content I am building.
For example, if the metadata was:
metaSuffix:\n\n
and I have read that in and parse that into a javascript variable after removing config label:
var suffix
(suffix is now ‘\n\n’)
And I want to create a new draft:
var stringVar = “This is a test”;
d = Draft.create();
d.content = stringVar + suffix;
the draft is:
This is a test\n\n
Rather than the phrase followed by a blank line.
I am going to build a function to look specifically for the ‘\n’ and build a string using the interpolated “\n” but I am wondering if there is a simpler way?
