Hi, I’m new to Drafts and have enjoyed using it enough for the past few days to give the Pro upgrade a try.
After upgrading, all of the Actions that were available to me all disappeared from the actions list. Do I need to add them all back one by one, or is there an easier way to retrieve them?
Actions shouldn’t appear when you apply the Pro subscription upgrade. That kind of sounds like it would be worth sending in an e-mail to the support address: within Drafts, select Settings > About: Send Feedback.
The standard groups (which contain the standard acions) I think should also be available on the Action Directory.
I have something similar that I’ve emailed Support about, in that three of my Action Groups now have zero actions, and I can’t think what I might have done to make it so. The actions just were there one day, and gone the next…
I know this is an old post, but were you able to get this resolved? I have an action group that did the same thing - they were there and then they weren’t. Not in my backups either.
