This is my first newbie forum post at drafts. I am just getting started with the app and have a few questions period
On the iPhone I am able to append to iCloud journal. However on the iPad when I click append to iCloud journal I get a red warning and it does not work.
I am able to append to dropbox on both devices ok.
Thanks for the help. The content is a simple sentence.
on iPad - I can save to reminders - and to iCloud Folder but append error in action log says: the operation couldn’t be completed. Draft store action error error 6
I will also mention that there are two draft folders in iCloud possibly one from an old version with a light icon and another one with a dark icon. There is only test data inside and I could easily delete one if you suggest that.
The app determines where to write to. The difference in folders will simply be because you have used a version of Drafts in the past that is the legacy (pre v5) version.
You can change the output folder, but only by adding further sub folders. I.e. Not which Drafts folder - that simply isn’t how app sandboxing works.
You have not noted if you can see the journal file in the Files app on your iPad as I asked earlier. Can you confirm this? If you can’t see it, that would be a good pointer as to the cause of the error you have encountered.
I unchecked the iCloud permissions for Drafts - and then tried sending and it’s failed and then I went back in and rechecked the iCloud permissions for drafts and now everything is working just fine !!!
Thanks so much we’re hoping to get this working again!!!
Dave
