Next, I tried a Shortcut but the Process Template action requires a draft. I could use Run Action with Text and use New Draft from Template but I have a lot of templates and just want one specific template.
I’m not great at modifying Actions but assume that’s my best course since I could run it through the url scheme.
How about creating an action with the create draft step set up to create your new draft in the way tou want? Then use a hyperlink for the Drafts URL scheme to trigger the action.
Note the OP wants to create a new draft from a template and trigger from a hyperlink. Text insertion action steps on their own do not create a new draft (hence my suggestion for the create draft step above), and you still would need the URL scheme action link format to trigger it as a hyperlink.
Just using what you suggest could end up inserting th template at your current cursor position in an existing drafts when triggered.
Thank you! That works beautifully and I hope it helps others out. I find it convenient to keep templates outside of scripts for easier updating. Every little bit helps with those routine tasks. You’re the best!
