Have you hit the (x) to clear filters on the list? If so, if you show the search field and search for something - and/or use quick search - do they show up?
It seems likely you have some query filter applied to your list limiting the result.
You have date range filters applied to your list, so that it is only showing drafts created at 5:26 AM UTC on May 21st, 2021. Which you very likely do not have any of…
Go to list options (...) and remove those filters and all your drafts will be visible. It seems likely you were poking around at some point and unintentionally added those filters.
After removing them, also select “Save as Default” to update your default workspace so these filters will not get applied again.
