Multimarkdown 6 provides for Table of Contents and a simple way to key links to selected headings. I am familiar with this from other iOS markdown apps.
I can’t make jump links work in Drafts, nor a TOC.
This is a facility I rely on in longer notes, especially in speaking/teaching/discussion situations.
Is there another way to provide internal links, or will future releases bring improved MultiMarkdown functionality? Or other suggestions?
The Multimarkdown {{TOC}} Table of Contents generation is supported if you are using MultiMarkdown as your Markdown generator.
There is a slight gotcha, however, due to the fact that the double curly braces conflict with Drafts’ template engines use of those markers for URL encoding. To get the table of contents inserted in your preview, you must escape it to prevent URL encoding handling it before MultiMarkdown gets a hold of it - so use \{{TOC}} (note leading backslash excape character.
Have tried this with and without the leading backslash character and MultiMarkdown selected. Not working.
It’s easy enough to construct a TOC from links, so it’s not a big deal.
I find Markdown/MultMarkdown doesn’t pick up the # and ## headings etc so it is necessary (at the moment) to insert a line with . Would be a timesaver if it all worked “like it says on the tin” but hey!
Could you provide example text that demonstrates this not working? Does the example above not work for you? If not, it’s likely a matter of the appropriate MultiMarkdown settings being enabled.
Check you Markdown settings. Specifically the Markdown compatibility mode is one possibility that could cause what you are seeing as it effectively turns off Markdown extensions like TOC.
