On the Mac app, I’m missing the button that let me navigate the different headings in the document. Not sure exactly when this went away. Any way to re-enable it?
That’s puzzling. It should still be there. Try a quit and relaunch? Maybe the system layout engine is having a moment.
If that doesn’t help, what happens if you open it from the menu command? (Editor > Navigate)
quitting and relaunching doesn’t bring it back. But the menu command does work. Here’s two screenshots that might give more detail.
Try showing tag entry, does it appear then?
yes, ok, there it is. I was expecting it in the same place as the iOS app, but I remember now that it hasn’t been the same for some time.
That is a bug. The navigation button should remain when tag entry is hidden. I’ll fix that in the next update.
