I type my process writing in Drafts on my iPad. After several paragraphs, there are menu bars across the bottom of the page. I have found no way to reposition or remove these floating menu bars. They cover so I can’t see the current line I am typing. I do not have this problem on my iMac which has a much bigger screen. Is this an issue or have I just not found a simple work around or system setting?
You can hide them in Editor Settings. I’m not sure I understand if you just want to hide them, or if they are interfering somehow?
The menu bar floats over the page at the bottom. The menu bar does not interfere with typing, but covers it so I can’t see the line being typed.
OK, so an overlap. That shouldn’t happen. You can hide or collapse the bar if it’s in the way, but I’ll review and make sure the offsets don’t need some adjustment.
What iPad model and OS version are you running? Sometimes these issues are specific to certain device/OS combinations.
I’m on an iPad Pro, 13 inch, M4. There is a “>” on the side of the menu bar that makes it disappear, but it comes right back as soon as I start typing. I don’t know how to collapse the bar and continue typing.
