The search command is particularly cumbersome to use. Could it support sorting by time and filtering by tags simultaneously just like the Draft.query() function?
Take a look at the list function. It does not have sort, but has those additional filtering options.
Or, for more control of a repeated query set, create a workspace in Drafts to define a detailed filtering and sort configuration and load the drafts from that workspace with the MCP or CLI.
