Marked 3 Integration
Marked 3 for Mac is now official.
It would be great if the Streaming Preview support was updated to support Marked 3
I edited your Preview in Marked action: I changed x-marked://preview?text=[[draft]] to x-marked-3://preview?text=[[draft]]. That seems to work. Hope I didn’t screw something else up.
Thanks
Bob
I don’t think there are any changes needed. The streaming preview works as-is for Marked 3, and the example preview action also works. The new version shares the same pasteboard for streaming, and both use the x-marked:// URL - if you are keeping both Marked 2 and 3 installed on your device, your system might be registering the wrong version as the default for that URL scheme.
Yep, I’ve got both versions.
Marked.app a.k.a. Marked 3
Info.plist
CFBundleURLSchemes
marked
x-marked
x-marked-test
x-marked-3
Thanks
Bob
