Is there any possibility, using macOS, to open a md file (markdown) or text file using Drafts by default as you can do with Text Edit or Apple Notes ?
If I right click and choose “Open with” in Finder, Drafts is not available for markdown files.
Could help using Drafts as my universal text editor.
Any best practice appreciated.
Jean-Christophe
Drafts does not edit and save files. It has a database behind the scenes and can import and export files, but it does not work with files in the same way a text editor would.
Correct.
But you can open a text or markdown file in Drafts.
So the question was “is there any way to open such a file in Drafts from Finder” ?
Drafts registers for all text file types, and appears as an option for .txt, .md and other common plain text files in the “Open With” in Finder menu - or to be assigned as the default app for those types - on all my Macs.
Not sure why it would not be on your machine. Have you rebooted lately? Maybe just a temporary glitch with type registration.
