Two small improvements suggested for Mac:
If I’ve landed on a draft from somewhere other than the left panel/list of drafts, I can’t easily get to past Versions – I need to be able to run Get Info… on the draft, but it’s not a menu option – that might need to be added to the File menu?
To add an existing tag to a draft, I have to hit enter twice – once to let the app’s suggestion be used (after I’ve arrowed to select the one I want), then enter again for the tag to be accepted – seems like just accepting the suggestion should be enough
Reasonable points…comments in the meantime:
- Info is available using the
(i)
info button below the editor, or could be triggered with an action using the window.showDraftInfo()
function.
- You can also just leave the tag entry field. The tag will be accepted if you take any action the un-focuses that field.
Totally missed that (i) button, thank you
Last small issue @agiletortoise
On iOS, Get Info modal includes Action Log and Version History, but Mac doesn’t
I don’t really want to request File menu items and keyboard shortcuts for both of those – would it be possible to add to the Info modal on Mac to quickly get to Action Log and Versions? Basically to make the Mac modal look like iOS’s
