As an Alternative to Prompt and Paste, I am trying Paste and Parse.
How can I combine create new Draft with content and then parse it as the next action? I tried adding Parse Content as “Include Action” in Actions menu but I get an error message
Script Error: SyntaxError: Can’t create duplicate variable: ‘d’
Line number: undefined, Column undefined
If I add One script and then another, it does not work either. What is the best way to combine them?
Action 1 - New Draft with Content to be Parsed
let d = Draft.create();
d.content = `Name: [[FirstName]] [[LastName]]
Date of Birth: [[DOB]]`;
d.addTag("prescreen");
d.update();
editor.load(d);
Action 2 - Parse and Update Take from Email Parsed Template
/******/ (function(modules) { // webpackBootstrap
/******/ // The module cache
/******/ var installedModules = {};
/******/ // The require function
/******/ function __webpack_require__(moduleId) {
/******/ // Check if module is in cache
/******/ if(installedModules[moduleId]) {
/******/ return installedModules[moduleId].exports;
/******/ // Create a new module (and put it into the cache)
/******/ var module = installedModules[moduleId] = {
/******/ i: moduleId,
/******/ l: false,
/******/ exports: {}
/******/ // Execute the module function
/******/ modules[moduleId].call(module.exports, module, module.exports, __webpack_require__);
/******/ // Flag the module as loaded
/******/ module.l = true;
/******/ // Return the exports of the module
/******/ return module.exports;
/******/ // expose the modules object (__webpack_modules__)
/******/ __webpack_require__.m = modules;
/******/ // expose the module cache
/******/ __webpack_require__.c = installedModules;
/******/ // define getter function for harmony exports
/******/ __webpack_require__.d = function(exports, name, getter) {
/******/ if(!__webpack_require__.o(exports, name)) {
/******/ Object.defineProperty(exports, name, {
/******/ configurable: false,
/******/ enumerable: true,
/******/ get: getter
/******/ // define __esModule on exports
/******/ __webpack_require__.r = function(exports) {
/******/ Object.defineProperty(exports, '__esModule', { value: true });
/******/ // getDefaultExport function for compatibility with non-harmony modules
/******/ __webpack_require__.n = function(module) {
/******/ var getter = module && module.__esModule ?
/******/ function getDefault() { return module['default']; } :
/******/ function getModuleExports() { return module; };
/******/ __webpack_require__.d(getter, 'a', getter);
/******/ return getter;
/******/ // Object.prototype.hasOwnProperty.call
/******/ __webpack_require__.o = function(object, property) { return Object.prototype.hasOwnProperty.call(object, property); };
/******/ // __webpack_public_path__
/******/ __webpack_require__.p = "";
/******/ // Load entry module and return exports
/******/ return __webpack_require__(__webpack_require__.s = 0);
/* 0 */
/***/ (function(module, exports, __webpack_require__) {
"use strict";
var _templateTagParser = __webpack_require__(1);
var parser = new _templateTagParser.TemplateTagParser();
if (parser.ask()) {
var parts = [{
value: draft.content
value: draft.title
value: draft.content.split('\n').slice(1).join('\n')
value: editor.getSelectedText()
value: app.getClipboard()
parts.forEach(function (part) {
var parsed = parser.parse(part.value);
draft.setTemplateTag("parsed_".concat(part.name), parsed.text);
draft.setTemplateTag("parsed_".concat(part.name, "_html"), parsed.html);
} else {
context.cancel();
/* 1 */
"use strict";
Object.defineProperty(exports, "__esModule", {
value: true
exports.TemplateTagParser = void 0;
function _classCallCheck(instance, Constructor) { if (!(instance instanceof Constructor)) { throw new TypeError("Cannot call a class as a function"); } }
function _defineProperties(target, props) { for (var i = 0; i < props.length; i++) { var descriptor = props[i]; descriptor.enumerable = descriptor.enumerable || false; descriptor.configurable = true; if ("value" in descriptor) descriptor.writable = true; Object.defineProperty(target, descriptor.key, descriptor); } }
function _createClass(Constructor, protoProps, staticProps) { if (protoProps) _defineProperties(Constructor.prototype, protoProps); if (staticProps) _defineProperties(Constructor, staticProps); return Constructor; }
var TemplateTagParser =
/*#__PURE__*/
function () {
function TemplateTagParser() {
var template = arguments.length > 0 && arguments[0] !== undefined ? arguments[0] : draft.content;
_classCallCheck(this, TemplateTagParser);
this.template = template;
_createClass(TemplateTagParser, [{
key: "ask",
value: function ask() {
var tags = this.tags;
if (tags.length == 0) return true;
var prompt = Prompt.create();
prompt.title = 'Progress Report - Client Data';
tags.forEach(function (tag) {
return prompt.addTextField(tag, tag, '');
prompt.addButton('Okay');
if (!prompt.show()) return false;
draft.setTemplateTag(tag, prompt.fieldValues[tag]);
console.log("Setting ".concat(tag, " to ").concat(prompt.fieldValues[tag]));
return true;
key: "parse",
value: function parse(str) {
var text = draft.processTemplate(str);
var html = MultiMarkdown.create().render(text);
return {
text: text,
html: html
key: "tags",
get: function get() {
var reservedTags = ['body', 'clipboard', 'created_latitude', 'created_longitude', 'created', 'date', 'draft_open_url', 'draft', 'latitude', 'longitude', 'modified_latitude', 'modified_longitude', 'modified', 'selection_length', 'selection_start', 'selection', 'time', 'title', 'uuid'];
var pattern = /\[\[([\w ]+)\]\]/g;
var tags = new Set();
var match;
while (match = pattern.exec(this.template)) {
tags.add(match[1]);
return Array.from(tags).filter(function (tag) {
return !reservedTags.includes(tag);
return TemplateTagParser;
exports.TemplateTagParser = TemplateTagParser;
// Update content
//draft.content = draft.processTemplate("[[parsed_draft]]");
//draft.update("[[parsed_draft]]");
// Create a new draft from existing
var d = Draft.create();
d.content = draft.processTemplate("[[parsed_draft]]");
d.update();
editor.load(d);
draft = d;
