I have created a checklist in Drafts5 that I want to refer back to when I do a specific weekly task. Is it possible to link back to that draft from an Omnifocus task?
You can click the info icon at the top of the draft and an option to copy a link to the draft is near the top of this screen. Paste that wherever you need and it’ll open Drafts directly to the draft you’ve chosen.
That is perfect. Thanks so much for the quick answer.
You can also use this clipboard action on the Draft you want to refer back to in your OF task, and then just paste it where you need it.
