My Library Summary shows 18 items with the tag “pending” which I no longer use after replacing it with “status::pending”. When I search for items with tag “pending” the search finds nothing.
Can I clear or rebuild the Library Summary?
I believe the action you are referring to is just querying live.
Check if you have any Drafts with those tags in your trash folder. If not, go back and check your All folder.
If you want more stats and more details (down to showing what tags are in your trash), take a look at the TAD-Display Drafts Counts action in this action group.
Thank you. The Drafts with “pending” were, as you suggested, in the trash folder.
