Lag in v53. Update?
I have 400 notes. I’m getting interface lag on MacOS when scrolling up and down. Version is 53, but I can’t see anything in the changelog addressing this. I’ve gone through the maintenance options.
By the way, where is the update option? Not in About or settings menu. My apologies for a silly question.
Is there a way to tell if it’s actually drafts or something else on the system? No other winows are lagging. macOS is Tahoe Version 26.6.2
Drafts is distributed through the Mac App Store. Check for and install updates there.
Not aware of any general performance problems, if it persists after you update and restart your system to check on possible system temporary issues, open a support ticket with details (use “Send Feedback” in Help menu).
Many thanks. The update seems to have fixed it. Funny how I missed the Mac store. I barely use it
