I love having keyboard hotkeys to toggle left and right pane visibility in Obsidian.
Any chance we could get hotkeys for that in Drafts? Makes it must easier to focus in on a single note when needed, then add context with left panel, right panel or both.
⌘-0 and ⌘-1 are what you are looking for…in the “View” menu in the main menu.
Thank you! I love this. Is there any chance these could be configurable hot-keys in the future?
On Mac, you can re-assign menu command keyboard shortcuts for any app in System Settings > Keyboard > Keyboard Shortcuts. That’s a system-wide feature.
Or, alternately, you can install actions that do the same thing and edit them, assigning a custom keyboard shortcuts (this will work on iPad/iOS also):
