nello
May 20, 2022, 3:41pm
1
I’d like to enhance my Mailto Action so that the email subject is converted to TitleCase.
I’ve search here for “title case” but I just find Actions that change case within a Draft. I’m looking for coding suggestions to use within an Action.
Should I somehow incorporate a snippet from another Action, e.g., TAD-Title Case Selection from ThoughtAsylum - Writing ?
Sorry if that’s rude or considered plagiarism. I really don’t know what I’m doing.
Thank you.
The Title example action has a re-usable, open-source toTitleCase extension you could re-use.
That function extracted:
* To Title Case 2.1 – http://individed.com/code/to-title-case/
* Copyright © 2008–2013 David Gouch. Licensed under the MIT License.
String.prototype.toTitleCase = function(){
var smallWords = /^(a|an|and|as|at|but|by|en|for|if|in|nor|of|on|or|per|the|to|vs?\.?|via)$/i;
return this.replace(/[A-Za-z0-9\u00C0-\u00FF]+[^\s-]*/g, function(match, index, title){
if (index > 0 && index + match.length !== title.length &&
match.search(smallWords) > -1 && title.charAt(index - 2) !== ":" &&
(title.charAt(index + match.length) !== '-' || title.charAt(index - 1) === '-') &&
title.charAt(index - 1).search(/[^\s-]/) < 0) {
return match.toLowerCase();
if (match.substr(1).search(/[A-Z]|\../) > -1) {
return match;
return match.charAt(0).toUpperCase() + match.substr(1);
Include that in your script, then you will have a toTitleCase() function you can call on any string literal or variable.
nello
May 20, 2022, 3:57pm
3
Thank you. I searched but didn’t find it.
By the way, according to the GitHub History/Changelog , the function has been updated (in minor ways) from ver 2.1 to 2.2.1 as of 2018-09-07.
You could include the TAD action then use this TADpoLe string function. It is based on the same case function, but with normalisation included.
nello
May 21, 2022, 2:09pm
5
What does “normalization” mean/do?
Hopefully, this Wikipedia entry will explain far better than I could.
A text processing software implementing the Unicode string search and comparison functionality must take into account the presence of equivalent code points. In the absence of this feature, users searching for a particular code point sequence would be unable to find other visually indistinguishable glyphs that have a different, but canonically equivalent, code point representation.
nello
May 21, 2022, 8:28pm
7
Sorry to be so dense, but …
How do I include this?
Yes, I’ve found and read the Include Action documentation in the Drafts User Guide .
I meant just copy and paste it into the script step in your action, didn’t mean anything fancy.
nello
May 21, 2022, 9:33pm
9
With this test script:
console.log("enter script\n");
let strTemp = "this is the page title";
console.log("strTemp = " + strTemp );
let strPageTitle= "";
console.log("strPageTitle = " + strPageTitle + "\n");
strPageTitle = strTemp.toTitleCase();
console.log("exit script");
return match;
I get an error saying that toTitleCase() is not a function:
Script step completed.
enter script
strTemp = this is the page title
strPageTitle =
Script Error: TypeError: strTemp.toTitleCase is not a function. (In 'strTemp.toTitleCase()', 'strTemp.toTitleCase' is undefined)
Line number: 9, Column 35
The problem must be staring me in the face, but I don’t see it.
Move the toTitleCase() prototype definition to the top of the script. You are attempting to use it before you define it.
