Usually, it works fine, but since several days, I get a 401 error using Raindrop.io API. No change in my action script. The only change in my setup is iOS 17.4 update.
Anyone experiencing the same issue ?
Have you tried resetting your credentials in Drafts and issuing a test API call from a tool such as Postman? Maybe your access token has expired, or maybe there is an issue in Drafts, but the two tests above should help indicate where the issue lies.
The only 401 error references I see recently for Postman are ones you have posted on Reddit, so it does not suggest it is a wider issue.
Yes I resetted the token but still 401 error.
Never used Postman, thanks for the suggestion. I’ll give it a try.
I use other APIs with no problem ; I think the issue is only on Raindrop.
Thank you for your help ![]()
