When typing within [[ ]]
, a menu of options will pop up
If a link happens to be on the draft behind the popup, the click will go to that link
(The click should instead of course go to whatever I selected on the popup menu)
This happens with auto-correct, too (including on iPhone)
Touching the auto-correct suggestion could end up following a link behind
I guess I should do like most apps and just not have any links tappable while editing…because that’s really the only way to avoid this problem.
It’s too bad, because it can be useful in some cases to not have to dismiss the keyboard to use a link.
Just if the z order was respected (when menus/autocorrect are over links), it’d be fine to take clicks/taps at any time
