I created this keyboard action to function as a “smart tab” so that then the tab key is pressed:
- If there is no selection, the tab gets prepended to the current line instead of at the cursor position
- If multiple links are selected, tab is prepended to each line
- Cursor position (or selection start and end) is retained relative to the content
This works in all cases I’ve found except when the selected line has only list markdown and no other text, i.e. prepended with "- "
In that case the cursor always gets inserted one character to the left of where it should be.
I’m pretty sure this used to work but it’s been a while so I don’t remember how long since it was working.
Here’s the script
const list_re = /(^\t*[-*+] )/gm;
// grab state
let [lnStart, lnLen] = editor.getSelectedLineRange();
let lnText = editor.getTextInRange(lnStart, lnLen);
let [selStart, selLen] = editor.getSelectedRange();
let indent_lines = (l) => {
let lines;
if (l.match(list_re)) {
lines = l.replace(list_re, "\t$1");
} else {
lines = l.replace(/^/gm,"\t");
return lines;
let originalCursorPos = selStart;
let tabbed_text = indent_lines(lnText);
editor.setTextInRange(lnStart, lnLen, tabbed_text);
// Adjust cursor position based on indentation level
let indentationLevel = tabbed_text.search(/\S|$/);
let cursorPos = originalCursorPos + indentationLevel;
editor.setSelectedRange(cursorPos);
Can anyone help?
