Hi!
I know you can flag a draft, but is there a way to simply pin it so it shows up at the top? Thanks!!
Hi!
You can change the sort order in each workspace, so as long as you can uniquely specify it for the sort to be at the top, then yes. But there is no specific pin feature for an individual draft.
If you just want quick access, consider setting up an action (perhaps with a keyboard shortcut) to open it, or a Shortcuts shortcut for the particular draft.
There’s a setting to “sort flagged to top” for each workspace.
Awesome, thank you!!
