Is there a way to change key binds?
So I use Shottr for screenshots, and if I want to select a region by default it is CMD+Shift+2 however, this also pops up this New Draft window.
Is there any way to change the Drafts key binds rather than changing my Shottr key binds?
Thank you!
First page/tab of Drafts’ settings - see the Quick Capture Shortcut.
This might sound terrible, but where the heck are the settings? I can’t find them anywhere
Nvm, thank you (CMD ,) for anyone who might use this as a resource one day!
Thank you so much!
That’s the standard shortcut for any good Mac citizen app, and you’ll find it in the app named menu too as standard for those apps that display a menu.
