When sending Drafts to DEVONthink, is it possible to retain certain bits of metadata like “Date Created”, or even, perhaps, GPS coordinates for when the Draft was created?
Depends on how you export, but effectively, yes. Drafts can export to plain text formats. For example, if you exported to Multi Markdown, you might consider building an action that adds a YAML section to the start of the file containing the meta data you wish to retain in a format you would find most useful to access and process.
Oh, very cool! Didn’t even think of that. I appreciate the tip!
