I did choose a tab symbol for it specifically , but you can obviously choose any available symbol to use for a keyboard key.
Absolutely no need to apologise. We all misread things, make assumptions, etc. In the end, as long as you get where you need to go, then everything’s good
Besides, there may well be others now or in the future who encounter this same situation and be able to draw on your experience.
In regards to being ‘uncommon’, let’s just say that a tab character is tricky to find on an Apple iOS keyboard and perhaps not so tricky on others…
For what it’s worth, I actually use a TextExpander snippet* most commonly for tabs in Drafts when I’m not using an external keyboard; though I did create a tab action for the extended keyboard row for when I’m working with text that requires a lot of tabbing.
* Note I do use a TextExpander subscription to support this (I use it cross device and cross platform so definitely worth it for me) and unfortunately iOS’s built in text replacement functionality balks at just a tab as text to insert as it sees it as just whitespace and considers that invalid.
I am a Window man … could not warm up with Macs …
But i love iPad
Cannot get directly the next subscription, for TextExpander.
As i said … this is a catastrophe and all of you will learn that soon, when nothing is possible anymore without subscriptions! I am horryfied …
No cross platform in this case meaning iOS, MacOS and Windows for my TextExpander use. I’m fairly agnostic overall, but I’m a daily user of Windows and iOS at work with occasional Android and Linux. At home, it’s mainly MacOS and iOS with again some Windows, Android and Linux thrown in for good measure. But I’ve worked with more platforms than that over my career so quite honestly even if it has just a command prompt I’m usually fine.
We’ll have to agree to disagree in regards to the subscriptions base. But for those apps & services I get good value from, I’m happy to support them so they don’t just disappear or get left to ‘rot on the vine’ so to speak as has happened for quite a few of my favoured iOS apps over the years.
Anyway, that ‘subscription or not’ conversation’s been done to death in a number of places so I’ll take my leave of further discussion on that one here.
Yes, you are right, but when you post about “subscriptions are OK to support importand software”, i need to add at least that there is a better solution:
Pay for every major new version and drop support for the older versions!
Just to let a casual reader not think that subscriptions are without alternative.
Thanks, I assumed that was the case, but I didn’t know what the codes are called, and I didn’t know where to look it up! Is there a directory somewhere?
Hah, of course not! As soon as I got the %09, I went off to fix my problem! So thanks for sending me the reference as well as the answer to my question!
Drafts can do encoding for you as well by wrapping text in {{ }} in a template. Mind you, it’s not easy to type a tab character on iOS if you don’t have an external keyboard, but in general, if you are constructing URLs in action steps, it’s a good idea to just get in the habit of wrapping an parameters you manually input in the double curly braces, because there are a lot of other now common characters that need to be encoded for URLs. Like:
Just pasting the URL into your post should work just fine.
It would also be useful to share the detail of what you are doing and how you are doing it. E.g. Is the URL being embedded as text of Markdown in a draft or is it being opened by drafts as part of an action?
It is also useful to check/share the contents of the log if it is a draft action encountering an error.
