Hi everyone,
Is it possible to insert text from another draft through an action?
My use case: I keep various templates in one workspace within Drafts (meeting note, literature note, etc…) and would like to have actions to retrieve the content of a specific template and insert it into the current draft.
Is this possible?
I know, Drafts has a template system to retrieve template files from within the Finder/Files App but I would like to use Drafts itself as a repo for my templates because that way I can easily call them from the Shortcuts App to use in other automations as well.
Tag each of those drafts with a tag (e.g. “Client Ref”)
Create an action using the “New draft with Template” functionality to list out the drafts with the tag “Client Ref”
Find a way to add the content of the selected draft where the cursor is, instead of creating a new draft from the selection, which is what the “New draft with Template” function does currently.
Questions:
Is my approach above the best way to do this? Is there a better way?
Is anyone able to give me some guidance as to how to do it? If there are any basic JavaScript courses (preferably free) that I need to review to be able to help myself, I’d love recommendations. I have a problem solving mind, so not knowing what to do is extremely frustrating. That said, I’m also in an ADHD mess right now, so if this is straightforward and someone is feeling charitable, I’d love some help with the specific action.
Are you inserting the full content of the draft? Autocomplete has built-in support for inserting other drafts. Just type << and you’ll get a drop-down. Keep typing to filter list, select one, and it’s contents will be inserted at the cursor.
Thank you. I mis-read the guidance for new members and didn’t think I could post a new topic.
I have approximately 20 client reference numbers active at any one time.
I will look into the two other options you referenced, as that may be a much better way to handle the issue, I’ll also search regarding JavaScript. Thank you for replying so promptly!
