It would help to streamline the use of Prompts (especially when using Drafts with an external keyboard), if we could do the following:
- Set a field to be the default field with focus.
- Currnetlyt, it seems like you first have to arrow down, then press enter to give the first field focus and accept input.
- It would be nice if you could set a specific field to have focus when the prompt is displayed, or at a minimum, make it so the first field is focused and able to accept input.
- Be able to designate a “default” button and have a shortcut to select that button
- It seems that CMD+. maps to Esc, which selects the Cancel button.
- It would be nice if say CMD+Enter would select whatever is the default button (or if there is only one button, select that one).
Thanks,
Ed
