Anyone know how to do this? I’d like to have three colour states for lines that begin with either X, Y or Z. I only have an iPhone and find json hard to work with on this device. Thanks in advance
That can certainly be done with a custom syntax definition.
I highly recommend a JSON editor, especially if working on the phone. Jayson is a good one.
You can start with a syntax close to what you want (Markdown, or whatever) and export it. You would need to and three “patterns” that identify your lines using regex (something like ^X.* to find lines starting with X)…and have that scope matched to the colors you want.
Something like:
"match": "^X.*",
"exclusive": true,
"comment": "Lines starting with X",
"captures": {
"1": {
"scope": "color.red"
You can look in an exported theme for the available color. scopes in the default themes.
