Hi!
I installed the Template-Mustache and now it’s impossible to delete it.
How can I do to remove it?
I believe you are referring to the syntax definition, and you did not install it. It was added as a built-in syntax in a recent update, as it is used in template editing in actions, and cannot be removed.
Indeed. I am sorry for this.
So, there isn’t any way to remove it.
Can I solve the issue if I delete Drafts and install it again?
Why is it an issue, @nicfab ?
Probably I classified it as an issue and it isn’t correct.
I simply mean that I cannot remove Template-Mustache, but it isn’t a problem.
It is a standard feature. Even if there is a way to forcefully remove it, you should not.
