Hello, I asked a question and subsequently found the solution. How do I delete a Post?
thank you
Other people may have the same issue, so you should simply post what you found. It makes no difference who identified the resolution.
If you post something in error you can edit and delete it - such posts show as post withdrawn by user and there is a 24 hour stand still during which time I think an admin can recover it.
There’s abut more here, and I’m sure there are many other discussions about it on the Discourse forum (Discourse is the software used to run the Drafts forum).
Thank you for the info
