Hi,
I keep reusing certain functions in multiple script, the current approach that i do is copy paste the functions into multiple files
Wanted to check if there is a better way where I can write it in one file and reference that function.
Hi,
There are a number of ways to approach reuse, the two main ones:
iCloud Drive/Drafts/Library/Scripts and load it in other scripts using the require(path) function (docs).Perfect pt 2 was what I was looking for thanks ![]()
