I have an action the writes my Draft to Google Drive txt file for a trip journal. It captures the date and time. How do I capture and add my location (eg London, Boston, etc) to the journal?
Longitude and Latitude are captured as meta data if you have location enabled for Drafts. If you need a city/region, you could get Apple Shortcuts to convert those coordinates to an area and then either return that into Drafts to be set as a custom template tag, or you could have your action get Shortcuts to run the whole export.
I have a similar script that I use to get my latitude & longitude with:
var tempDraft = Draft.create();
var latlong = tempDraft.processTemplate("[[latitude]],[[longitude]]");
After that, I reverse geocode it with:
try {
// TODO Change to MapTiler API which is cheaper and provides better results.
let credential = Credential.create("Google Maps API", "Google Maps API Token from a Google Cloud Project");
credential.addPasswordField("google_maps_api_key", "Google Maps API Key");
credential.addTextField("google_maps_project_id", "Google Maps Project ID");
credential.authorize();
var url = 'https://maps.googleapis.com/maps/api/geocode/json?latlng=' + latlong + '&result_type=street_address&key=' + credential.getValue("google_maps_api_key");
var http = HTTP.create();
var response = http.request({
"url": url,
"method": "GET"
if (response.success) {
var data = JSON.parse(response.responseText);
if (data.status === 'OK' && data.results && data.results.length > 0) {
formattedAddress = data.results[0].formatted_address;
} else {
formattedAddress = "No address found";
} else {
formattedAddress = "Error fetching address: " + response.statusCode;
} catch (e) {
console.log(e);
formattedAddress = "Error fetching address";
